Interannual pre-processing
5. Interannual pre-processing#
Dedicated scripts for interannual pre-processing can be found for the different forcing datasets in:
Aforc_CFSR
Scripts for the recovery of surface forcing data (based on CFSR reanalysis) for
interannual simulations
Aforc_ECMWF
Scripts for the recovery of surface forcing data (based on ECMWF-ERAinterim simulations) for
Aforc_ERA5
Scripts for the recovery of surface forcing data (based on ECMWF-ERA5 simulations) for
Aforc_NCEP
Scripts for the recovery of surface forcing data (based on NCEP2 reanalysis) for
Aforc_QuikSCAT
Scripts for the recovery of wind stress from satellite scatterometer data (QuickSCAT)
Forecast_tools
Scripts for the generation of an operational oceanic forecast system
Oforc_OGCM
Scripts for the recovery of initial and lateral boundary conditions from global OGCMs
(SODA [Carton, 2005] or CMEMS/Mercator [Lellouche et al., 2021]) for inter-annual simulations
  1. Edit crocotools_param.m First section should already be set if you have completed the previous tutorial.
    In the second section, check the path to forcing data directory
    % 2 - Generic file and directory names
    %  Forcing data directory (ncep, quikscat, datasets download with opendap, etc..)
    FORC_DATA_DIR = ['~/DATA/'];
    In section 4, select only ini and bry (but no clim files, set: makeclim = 0;) to avoid too long pre-processing, and as it is the most usual set up
    %  initial/boundary data options (1 = process)
    %  (used in make_clim, make_biol, make_bry,
    %   make_OGCM.m and make_OGCM_frcst.m)
    makeini    = 1;   % initial data
    makeclim   = 0;   % climatological data (for boundaries and nudging layers)
    makebry    = 1;   % lateral boundary data
    Edit section 6 for running January to March 2005
    % 6 - Reference date and simulation times
    Ymin          = 2005;          % first forcing year
    Ymax          = 2005;          % last  forcing year
    Mmin          = 1;             % first forcing month
    Mmax          = 3;             % last  forcing month
    Note
    An important aspect is the definition of time and especially the choice of a time origin. The origin of time Yorig should be kept the same for all the preprocessing and postprocessing steps.
    Edit section 7 for using ERA5 and mercator forcing sets
    % 7 - Parameters for Interannual forcing (SODA, mercator, CFSR, ERA5 ...)
    Download_data = 1;   % Get data from OPENDAP sites
    level         = 0;   % AGRIF level; 0 = parent grid
                     %           1/1/1979 - 31/3/2011
    makefrc      = 0;       % 1: create forcing files
    makeblk      = 1;       % 1: create bulk files
    QSCAT_blk    = 0;       % 1: a) correct NCEP frc/bulk files with
                        %        u,v,wspd fields from daily QSCAT data
                        %    b) download u,v,wspd in QSCAT frc file
    add_tides    = 0;       % 1: add tides
    add_waves    = 0;       % 1: add waves
    %  Options for make_ERA5
    ERA5_dir    = [FORC_DATA_DIR,'ERA5_',CROCO_config,'/'];        % ERA5 data dir. [croco format]
    My_ERA5_dir = [FORC_DATA_DIR,'ERA5_native_',CROCO_config,'/']; % ERA5 native data downloaded
        % with python script
    itolap_era5 = 2;                                               % 2 records = 2 hours
    % Options for make_OGCM_SODA or make_OGCM_mercator
    OGCM        = 'mercator';        % Select OGCM: SODA or mercator
    OGCM_dir    = [FORC_DATA_DIR,OGCM,'_',CROCO_config,'/'];  % OGCM data dir. [croco format]
    bry_prefix  = [CROCO_files_dir,'croco_bry_',OGCM,'_'];    % generic boundary file name
    clm_prefix  = [CROCO_files_dir,'croco_clm_',OGCM,'_'];    % generic climatology file name
    ini_prefix  = [CROCO_files_dir,'croco_ini_',OGCM,'_'];    % generic initial file name
    OGCM_prefix = [OGCM,'_'];                                 % generic OGCM file name
    mercator_type=1;    % 1 -->  1/12 deg Mercator global reanalysis
                        % 2 -->  1/12 deg Mercator global analysis
                        % 3 -->  1/12 deg Mercator global forecast (See Section 8.)
                        % 4 -->  1/24 deg Mercator Mediterranean analysis/forecast (See Section 8.)
                        % 5 -->      the same than 4 but with detiding postprocessing on current and ssh
    %  To download CMEMS data: set login/password (http://marine.copernicus.eu)
    %  and path to copernicusmarine executable
    %  see Oforc_OGCM/Copernicus_Marine_Toolbox_installation.md
    %  Various sets of data are proposed in the Copernicus web site
    if strcmp(OGCM,'mercator')
    pathCMC='/path/to/home/copernicusmarine'; % copernicusmarine client
    user     = 'XXXX';
    password = 'XXXX';
  2. Then you can run the Matlab pre-processing for these interannual forcing: You should already have you grid set up. Otherwise, run make_grid
    To build your ERA5 interannual atmospheric forcing, script are in Aforc_ERA5/. Details are available in README_ERA5.txt. The download part used python script
    To build your CMEMS/mercator interannual ocean forcing, the useful script is Oforc_OGCM/make_OGCM_mercator.m. The download part used python script
    Warning
    As this pluri-month preprocessing can be longer and uses more CPU ressources, you may need to submit it as a job. A few example scripts (for SODA and CFSR) are provided:
    cp ~/croco/croco_tools/example_job_prepro_matlab.pbs .
    Launch your pre-processing job
    qsub example_job_prepro_matlab.pbs
  3. Check your generated files in CROCO_FILES You should have
    croco_blk_ERA5_Y????M?.nc
    croco_bry_mercator_Y????M?.nc
    croco_ini_mercator_Y????M?.nc
