4. Visualization tool (croco_pyvisu)#
Croco_pyvisu is a tool written in python to visualize history files genarated by the Croco model.
4.1. Setup your python environment#
A global conda environment is available for the three parts of croco_pytools in the env.yml file, located at the root of the croco_pytools directory..
You can use your favorite python environment manager (e.g. conda, mamba, micromamba, miniforge) to install the environment named croco_pyenv with this file.
Example with micromamba :
micromamba create -f env.yml
micromamba activate croco_pyenv
Example with conda :
conda env create -f env.yml
conda activate croco_pyenv
4.2. Croco_pyvisu directory#
The croco_pyvisu directory is provided in the CROCO_PYTOOLS. Clone the croco_pytools git:
git clone https://gitlab.inria.fr/croco-ocean/croco_pytools.git
cd croco_pytools/croco_pyvisu/
Install croco_pyvisu in the conda environment (command launched in the croco_pyvisu directory)
pip install -e .
4.3. First, you have to customize for your own history files#
The only file you have to change is the file croco_wrapper.py. You have two files as examples in the repository:
  • croco_wrapper.py.benguela for the Benguela test case, where history files are created through the classic method.
  • croco_wrapper.py.moz where the history files are created through XIOS.
Choose the right one to start :
cp croco_wrapper.py.benguela croco_wrapper.py
In croco_wrapper.py, change path and keymap_files to load the right files
path = "./"
keymap_files = {
  'coordinate_file': path + "croco_his_Y2008.nc",
  'metric_file': path + "croco_his_Y2008.nc",
  'mask_file': path + "croco_his_Y2008.nc",
  'variable_file': path + "croco_his_Y2008.nc"
  • coordinate_file : containing lon_r, lat_r, time
  • metric_file : containing pm, pn, theta_s, theta_b, Vtransform, hc, h, f
  • mask_file : containing mask_rho
  • variable_file : containing ssh, u, v, w, temp, salt, rho
Change the keymap_* dictionnaries to suit your files, you must only change the keys, that is the values on the left before the “:”
keymap_dimensions = {
    'xi_rho': 'x_r',
    'eta_rho': 'y_r',
    'xi_u': 'x_u',
    'y_u': 'y_r',
    'x_v': 'x_r',
    'eta_v': 'y_v',
    'x_w': 'x_r',
    'y_w': 'y_r',
    's_rho': 'z_r',
    's_w': 'z_w',
    'time': 't'
keymap_coordinates = {
    'lon_rho': 'lon_r',
    'lat_rho': 'lat_r',
    'lon_u': 'lon_u',
    'lat_u': 'lat_u',
    'lon_v': 'lon_v',
    'lat_v': 'lat_v',
    'scrum_time': 'time'
keymap_variables = {
    'zeta': 'ssh',
    'u': 'u',
    'v': 'v',
    'w': 'w',
    'temp': 'temp',
    'salt': 'salt',
    'rho': 'rho'
keymap_metrics = {
    'pm': 'dx_r',
    'pn': 'dy_r',
    'theta_s': 'theta_s',
    'theta_b': 'theta_b',
    'Vtransform': 'scoord',
    'hc': 'hc',
    'h': 'h',
    'f': 'f'
keymap_masks = {
    'mask_rho': 'mask_r'
4.4. Launch visualization#
To start croco_visu:
croco_gui_xarray.py
The main window is opened.
../_images/figure1.png
First, you have to choose a variable through the Croco Variables… menu, which list all the 2D/3D variables of the history file.
../_images/figure2.png
Min/max Time of the file are filled out You can type a time in the Choose Time input box. The nearest time of the history file will be retrieved.
Warning
Each time you type something in an input text box, you must validate the input with the “Enter” key.
../_images/figure3.png
Min/max level and min/max depth of the file are indicated You can type a level or depth in the input level/depth box (>0 means level, <=0 means depth), by default, the value is the highest level
../_images/figure4.png
You can type a longitude/latitude in the input longitude/latitude box (default is the mean longitude/latitude)
Now you can click on the Level/Depth Section button and a new window appears.
../_images/figure5.png
In this new window, you can only plot the current variable at the current level/depth. If you want another variable, or another level/depth, you have to choose first another variable or another level/depth and click again on the Level/Depth Section button. Then you will have another new window.
This new window offers several buttons and information:
To change the current time, you can type a new time in the text box or use the arrows
../_images/figure6.png
To zoom, translate and save the plot
  • To zoom, you have to first click the Zoom button and after select the region to zoom.
  • To translate the plot, you have to first click the Pan button and then move the plot with the left mouse button.
  • The Home button is to go back to the default view.
  • The Save Plot button will open a new window for you to save the current plot.
../_images/figure7.png
To create animations You have first to choose the start time and the end time in the two input text boxes. Then you can click on the “Animation” button to start the animation. You can abort the animation with the “Abort” button . If you select the “Save Anim” button, your animation is saved in a “Figures” sub-directory.
../_images/figure8.png
To change the colorbar To choose new limits for the colorbar (return to validate the input). You can go back to the default colorbar with the “Reset Color” button.
../_images/figure9.1.png
To show contours of the topography. You can show the contours of the topography by clicking on the “Topo” button (on/off). You can change the number of contours shown in the text input box (return to validate the input, default is 10).
../_images/figure9.2.png
To see the coordinates of the current point. At the right bottom corner of the window, you have the coordinates of the cursor.
../_images/figure10.png
On the main window, the two others buttons Longitude Section and Latitude Section will open the same kind of window than the Level/Depth Section but at a given longitude or latitude.
../_images/figure11.png
Of course, to have a longitude/latitude section, you must choose a 3D variable. You have to choose first the longitude/latitude before clicking the buttons. The longitude/latitude can be typed in the text input boxes near the buttons, or you can click on a plot to select a new point. If you click on the plot of a
  • Level/Depth Section, you select new longitude and latitude.
  • Longitude Section, you select new depth and latitude.
  • Latitude Section, you select new depth and longitude.
The two last buttons of the main window Time Series and Vertical Profile create new windows to plot curves.
../_images/figure12.png
Both Time Series and Vertical Profile have the same possibilities.
../_images/figure13.png
  • Zoom a part of the curve: you must first select the Zoom button and then select the region to zoom.
  • Pan the curve: you must first select the Pan button and then translate the curve.
  • Home to go back to the default view
  • Save Plot : when you click on the Save Plot button, a popup window is opened for you to choose the name of the file.
The time series is plotted at the current level/depth, longitude and latitude. The vertical profile is plotted at the current longitude/latitude. You also have the coordinates of the cursor at the right bottom of the window.
4.5. How to add new variables#
In the main window, you have another menu called Derived Variables…, which contains calculated variables, derived from the base fields found in the history file.
../_images/figure14.png
Right now, available variables are
  • pv_ijk
    Ertel potential vorticity is given by
    \[\frac{curl(u) + f}{rho}\]
  • zeta_k
    zetak is given by
    \[\frac{\partial{v}/\partial{x} - \partial{u}/\partial{y}}{f}\]
  • dtdz
    dtdz in given by
    \[\frac{\partial{T}}{\partial{z}}\]
  • log(Ri)
    Ri is given by
    \[\frac{N²}{(\partial{u}/\partial{z})² - (\partial{v}/\partial{z})²}\]
    with
    \[N=\sqrt{\frac{-g}{rho0} * \frac{\partial{rho}}{\partial{z}}}\]
You can add new variables by:
  • in the file CrocoXarray.py, add a line in the method list_of_derived:
def list_of_derived(self):
''' List of calculated variables implemented '''
keys = []
keys.append('pv_ijk')
keys.append('zeta_k')
keys.append('dtdz')
keys.append('log(Ri)')
return keys
  • in the file derived_variables.py, add two functions get_newvar and calc_newvar to calculate the new variable
  • in the file croco_gui_xarray.py, add the calls to the new function get_newvar in updateVariableZ, onTimeSeriesBtn and onVerticalProfileBtn
